'84 Original Hub Caps
RedTruck
Does anyone have a picture of what the original hub caps would look like on an '84 F250 or F350 4 wheel drive? Is there a difference between the extended cab and regular cab versions? I looked through LMC. It lists front hub caps for an '85-'92 F250 but not '84. Also they don't show a picture. I know they'll fit, but I'm wondering if that's original to an '84.
Thanks for any help,
Paul
Diesel Fly
Body By Rustoleum
Kensington, MD
I'm not exactly sure what year this is but they should look something like this
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
This is the factory rear hubcap on my '84 4x4...I've since replaced them with the "ashtray" style caps like you typically see on '86-'93 or so trucks (as seen on the second picture)...
RedTruck
Reese,
According to what I saw in LMC those are hub caps from an '85. BTW that's a sharp looking rig. Is that yours?
Tim,
Yep yep. That's the rear from an '84 but what the heck does the front look like? I'm leaning towards the idea that an '84 4x4 F250 came with rears, but not fronts. Also, can you provide more information on the circled item in the following picture?
Thanks fellas!
The Warden
MiB Impersonator
There ARE front hubcaps for a 4x4 with that design. I don't have a close-up of mine, unfortunately, and the original hubcaps are about 400 miles away at the moment. I took an early "overall" picture of my truck, and blew up the front wheel, so you can kinda get an idea of what it looked like. It essentially looks like the rear hubcap, except with a hole cut in the front for the hub to stick out...and, the area right around the hole is dished in somewhat. The black outline like you see in the rear hubcap has largely been worn off on the front, in this picture. Actually, the rear cap in the picture was the only one that was in decent shape; the others were all pretty badly beaten-up...that's a big part of why I replaced them, and I ran without hubcaps for a number of years after pulling those off and before getting the ashtray-style caps.
BTW, I have yet to see the front 4x4 hubcap in that style available at LMC, or new anywhere else for that matter. Maybe try eBay?
It's a foothold...there's one on each side. The first owner (my uncle's step-father, who bought the truck new) put them on, because he was short enough that he couldn't reach the windshield to wash it without those in place :D I think they're available at truck parts stores (I've seen them set up like a ladder on the side of a sleeper on a couple of trucks), and I've also seen them at West Marine. He cut a wood block to the contour of the sheetmetal to serve as a spacer for the foothold. I attached a close-up picture of the foothold, if that helps any. I don't need it for the windshield, but it sure makes it easier to replace the center clearance light :D
RedTruck
Tim,
Hmmm. I Haven't 100% decided whether I'm headed for the bone stock look yet or not. That front hub may just decide it for me. I'll have to check a few bone yards around here when I get a chance. Are you looking as well or satisfied with what you have?
That foot hold is a good idea. I was thinking more like....
Thanks,
Paul
flatlander
plays dirty when losing
ft. wayne IN
You're truck is beautiful. I'm trying to convince Mel to restore his back to this.
Mostly because I want that half cab off the Moose Truck
Diesel Fly
Body By Rustoleum
Kensington, MD
Unfortunately, no. That is a picture of "the one that got away". A friend of mine's dad was selling it and it was in better shape than the pictures you see! I called him back to tell him I'd buy it and he said "I just sold it 5 minutes ago". I was grumpy for about a month after that -cuss
I still have pictures of it to remind me and to use as a goal for my truck.
LOL Here is a mostly stock Moose Truck.
Looks silly. LOL
I'd check with Doug Bensen for all those back to stock quests. He did a frame off restore of his, and seemed to find all those parts new somewhere, including hubcaps I believe.
RedTruck
Darrin,
Thank you very much. I haven't completely decided on the look I'm going for, but I'll definately keep that in mind.
Again thanks,
Paul
RedTruck
Mel,
I already checked out your pics. Good view of the grill...just not what I was looking for. I thought if anyone had a pic of a stock '84 you would.
Thanks none the less,
Paul
f-two-fiddy
Duluth, Mn.
From what I understand, the 'Dog Dish' hub caps were changed slightly in 85. The shape of the stamped lug looking design, and the contrasting black paint are just a bit different than earlier years.
The LMC paper catalog used to show the differences.
The blue '84 that Diesel Fly posted are OEM 84's.
The ones the Warden posted are the 85+
Lets not forget that the XLT's usually came with the hub caps that covered the whole wheel.
Diesel Fly
Body By Rustoleum
Kensington, MD
Here's two pictures of the front of a stock '84 (mine) and "the one that got away":D
Diesel JD
Gainesville, FL
I have some nice original hub caps but mine is an 86 2WD a lot different than those I'll get you a pic if you want.
