...might go take a look at it, not too far from me, body looks good in the pics. It's an early 6.9 but if it has gone this far it should be OK.
cheers,
The HD44 used regular Dana 44 lockouts, but has a spindle with 8 bolts instead of 6, and 8 lug rotors. I believe the bearings are the same. Also, it has a D50 upper ball joint, but D44 lower, if I'm not mistaken.
