CrippledEagle
Okay I searched the archives and didn’t find a solution although I did gain knowledge so thank you!
My 83 F250 is not switching tanks and the dash switch while functional is not making the tank switch work. This switch is the older one with the flat pins which are almost non findable. I am hoping that someone has experienced this and found a solution. The ones listed as replacements for mine are built to sit at an angle with the lines interfering with the frame. Does anyone know where a 6 port valve assembly with the round pins that sits flat can be found?
I know that I COULD build a bracket, but I am old, tired, retired and get vertigo so probably no.
I put a later one on my 84 one ton bye using a round pin valve and plug but it was a real task and many foul words escaped my mouth. Just trying to avoid a repeat.
Thank You in advance!
