Not sure what a 80hp pump is but here goes. The injectors could likely be the Bosch 190hp injectors which are a popular upgrade. These injectors raise your power by 30hp over stock (giving you a total of 190). If the injection pump is a replacement unit, then it's likely that the rebuild shop tuned it up a bit which resulted in a gain of 50hp. That's the only thing that would make much sense but there's no telling.
With that said, you're probably at optimal MPG as it is. With a stock VE, most folks say to turn up the fuel screw 1/8" and that will get you a good increase in power and max fuel economy. You should see 20-24MPG in these trucks. Don't know what kind of truck you have, but for reference my '93 (see sig) gets 20mpg running 65 on the interstate and that's at stock power levels.
