7.3L IDI Specs. from Ford service manual
ah1988ford
florida
You may have to log in to view the attachments, you may also have to click on the attachment so you can zoom in and read the info.
I was bored so I had some fun with the scanner lol. Mabey this should get moved to the tech articles so it is easy to find.
ah1988ford
florida
Only allows 10 per post
ah1988ford
florida
I have everything detailed step by step I will post them slowly as I get to them it takes a while to do lol
I have all this information in my International Engine Service Manual exactly as you have posted here. My manual is listed as a CGES 435-1 dated July 1991. They are still available from International for around $60.00... Well worth the cost. Just read up on how to install the rear main seal.
Sw1tchfoot
Why do cylinders 7 & 8 have a different cylinder bore diameter?
(picture e.jpg below Crankcase)
The reason for that is the cdr attached to the intake manifold at the back and the angle the engine sits at. All the oil thats sucked into the intake manifold runs down to the rear most cylinders 7 and 8. So those cylinders get more heat from burning more fuel. Oil from the engine is fuel to these diesels. Now nobody will bore these engines like that either. Its only around 1/2 a thousands larger anyway.
Wheelsrollin
Staff online
