StevoBelievo
I bought a 92 F350 drw, Western Hauler package. The mechanic I bought it from promised me it was a 7.3 and only needed a new head gasket, but I soon discovered it needs a lot more. In short, the engine needs rebuilt. A task I thought a friend and I could tackle.
The machine shop told me the cylinder head for the engine was for a 6.9, so I thought it must have had an engine swap.
I had the cylinders measured to know if they were ever bored out and find that it's bored out to the same specs as a 7.3.
My question is, can I put it back together as is with the thinner 6.9 cylinder head and some high end engine studs?
My concern is that if I do a rebuild and use the 6.9 head the higher compression for the 7.3 will warp the head and ruin the engine, waisting a lot of time and money.
Shops and individual mechanics I've talked to have said, "Well if it was running before it will probably be fine."
I am hoping for a more informed/knowledgeable answer.
Thanks y'all
Thanks y'all
