7.3 return line caps
nelstomlinson
Delta Junction AK
Its a 4" spacing, just cut 4" hoses and youll have it fit perfect each time, ...
What I've been doing is cutting the hose bits a little long, then letting them curve a little in between to take up the extra length. The olives end up sitting slightly diagonal rather than aligned fore-and-aft. It doesn't seem to keep them from sealing.
``Build it on the table'' is how I'll do it next time.
Edited to add: if you do one side at a time, you can keep the injector lines on the other side sealed, and have the engine running on one bank while you bleed the injectors on the other bank.
Selahdoor
Index Wa
That's what I did, too.
I did do the "on the tailgate" method. But I made each line just a bit long. I just feel I got a much better seal this way.
Also, before I even started to build the new one, I took all the caps, and used a piece of sandpaper around the inside bottom rim.
Just the rim. Not up inside.
I did this to improve the chamfer. Also greased this chamfer, and not just the o-rings themselves, before putting the caps on.
I think the next time I do this, I am going to use silicone grease.
tke395
