7.3 idi turned up?
Mishka
Fort Knox, KY
So I'm pretty sure my old pump was turned up but I just want to confirm....she rolls coal when floored (parked, not always when driving) and when accelerating up a steep hill empty going 70mph (gets to 70mph in a good time too) she lays down a trail of black smoke. She's also pretty peppy for being a N/A motor as she easily spins my yokohama geolander g003,s
Sound about right for a pump that was turned up?
mintmoballen
Benton County, OR
yeah sounds about right for a pump that's been turned up. if I were you I would turn the fuel back until you only get a very light amount of smoke coming out the exhaust under heavy load. any more than that and you're just ******* your money away in the form of smoke.
Mishka
Fort Knox, KY
For sure, I actually have a new pump coming but I was just wondering if my suspicions was right
Austin86250
idaho
is turning up your pump bad? will it decrease its life?
i was wanting to turn mine up
Mishka
Fort Knox, KY
You have to worry about EGT's I always was scared to go up this steep hill at 70mph because of all the smoke it would put out.....I suspected it was turned up ever since i first saw it roll coal but wasn't sure.
I will say my truck being a N/A 7.3 had similar driving style to the 2014 f150 fx4 5.0 I use to daily. I'm curious how it will do with the stock pump but I also might just get R&D's N/A injector pump which is slightly turned up and just throw a pryo meter on (I'm getting a egt gauge regardless of which pump I go with).
I feel like whoever turned my truck up knew what the was doing as it got over 20mpgs on the highway with the 3.55 gear ratio and e40d on 285/75/r16 M/T's
