You see im a farm boy and we make everything we need im a mechanic and can weld so when i build this for around 4,000 and your reading about my idi race truck competing with the cummins and strokers well see who says it cant be done then.
4wd is for launches on the drag strip, just remember that your going to be stuck with 4.10, they don't make 3.55 for Dana axels, at least not that I've found.
not really if you look at it propane adds 100 horse methanol adds 70 hp and the few other things will help but i want to be the one who has it and everybody says i want to do something like him build something that hasnt been built before
dont get me wrong but did you read the article in diesel power about the worlds fastest gm 6.5td its topped out at 500 hp and is rebuilt every 1500 miles and im sure tens of thousands of dollars spent annualy just to keep it going .
i say a ford idi can do it to but i think the bigger issue is money than anything id say getting over 400 hp out of an idi means everything custom built
Maybe if you have a power plant where traction during launches becomes a problem. I don't foresee that issue with an IDI.
Also, if you do stick with 4.10s...you will probably run out of RPM before you get to the end of the track. My truck even with a ZF5 is right at 2000rpm running just shy of 60mph.
I'm afraid I will have to side with others on this forum that have already chimed in. Love these trucks, but for all the custom parts it would require, you could have put some off the shelf parts into a powerstroke. Not trying to rain on your parade, you can make anything fast, but how much do you want to spend?
oops hunny i need a new motor my precup came out cause the boost was too high
(hope youre not married with these ideas)
but hey if you can do it wen you get bored with that truck ill take it
youll need a lot of custom work the major issue is the precup to make large hp cause a precup changes flows completely and it costs a ton to remove it
