Va_Mike
I have the old gasket scraped off and used a gasket stripper. But after two applications of the stripper there is still old graphite gasket material on the block and heads. Is it safe to use a brass wire wheel at low speed to clean the rest of the graphite off? The brass should be soft enough that it won't damage the machined cast iron sealing surface.
Thoughts?
Thoughts?
