7.3 air intake?
BIG DAVE
OILBURNER FOR LIFE!
kenai alaska
can i remove it with out removing the injector pump:dunnoi want to paint stuff on my motor, now i know i need to remove the injector lines and i'm planing to replace the fuel fitter at the same time and do the valve cover gaskets;Sweet
You can remove the lines from the pump without taking the pump out, but the bottom two lines will require the OTC tool made for the job, or a reasonable facsimile. Perhaps a crows foot with extension.
dyoung14
Is getting worn out
spencer,tn
so can i pull the injector pump with messing up the timing
dont pull the housing it bolts too, and when you pull the pump just be sure and mark the pump to the housing some way that way it will be exactly the place it was before
Bo17
