93cc7.3
needs turbo power
sorry i guess i should have been more clear i get that stuff i was wondering if the had the tcase forward of both axles and drove them like that or if the had the tcase in between the axles
FWIW,
I know a guy that added a dually tag axle to a '73 Ford dually. He used it to haul a pull sled for tractor pulling. It was there for a reason and it served a purpose...not just to look "cool".
Several years ago Dodge was going to do this same thing to a factory production pickup. They had prototypes and I believe a picture was posted in Popular Mechanics.
It has been a while since I took my class A permit test, but there is a reason heavy trucks have tandem axles...triple axles...quad axles...etc. Same reason there are a lot more tandem axle single wheel trailers available than single axle dually trailers.
Dually pickups are just a lot less expensive to produce and maintain than a tandem axle pickup.
It's dumb...really?!
Why doesn't the military cut one axle off the 5 ton 6x6's to replace the 2.5 ton 6x6's? One less axle, one less drive shaft, 4 less tires, 2 less leaf spring packs...and on and on. There must be a reason why?
To me it looks like a regular leaf pack above with a leaf pack below. It looks like the bottom leaf pack works like a traverse type spring setup. Kind of a new take on the walking tandem setup.
I think the guy is innovative. Betcha that thing can haul hay like no tomorrow.
Paul
if some one can explain to me how to get pictures from my computer to here I'd be glad to post some, I'm technology challenged
