67 F100/250 Conversion with ATS Turbo'd 7.3L Swap
67-7THREE
Brentwood, CA
some quick pics of the motor mounts, driverside isnt done yet, still need to drill 2 holes then weld it to crossmember. but you can get the idea..
67-7THREE
Brentwood, CA
motor is fully bolted down! driverside mount is welded and finished.
67-7THREE
Brentwood, CA
going 4 wheel drive now!
picked up a 8 lug HP dana 44, PS box and 4" lift
67-7THREE
Brentwood, CA
update, been awhile since i posted.
front axle has been cleaned and painted
axle mounted with leafs and custom shackle mounts
3" blocks in rear
add a leaf in front and rear (not installed yet)
3" body lift
started boxing frame
and other little things
will get some pics soon once axle swap is more done!
truck sits 12" taller without the add a leafs. im pretty happy where its at!
67-7THREE
Brentwood, CA
bodylift on bed is done, and installed add a leaf in the rear. sitting right where i want it!
manimal
Cherry Valley,Ca
Do you have any pics of the front suspension on the truck??? Thanks. BTW this is gonna be a sweet truck when done.
67-7THREE
Brentwood, CA
yeah i can go take some, its pretty much done except for shock hoops but ill will take some pics this weekend after i clean everything up and paint it.
and thanks!
