6.9 towing
john greer
having problems pulling 7000lbs up hills with my 86 6.9l ats turbo.
puttin out 8 psi. dont have a clue what gear i have in it.
also blows little black smoke.
is there any thing else i can do??
sle2115
NRA LIFE MEMBER
Southeast Ohio
Automatic I assume?
How old is the injection pump? Injectors? Has it been timed lately? Fuel filters changed lately?
How about your air filter? With 8 pounds of boost you should have plenty of power, and it seems with the black smoke your getting plenty of fuel to it. Seems like you need more air, or you've got a timing issue. What axle code do you have, and what kind of grade are you trying to go up?
john greer
new ip, injectors, injector cap and o rings
my ip is inline with the line on the oil fil neck
which way would i turn it to get more power?
not sure about grade these hills in arkansas.
o yea put an electric fuel pump on it to.
I think that static timing is your biggest problem right now. You really need to get it timed by somebody who has the right tool and knows how to set up an IDI. You can experiment with your timing, but unless you get it right on, it will never be 100%. Try rotating the pump towards the passenger side about a dimes width. I've seen some pumps go up to 1/4" away from the mark, but no more. Too much advance is worse than too little.
sle2115
NRA LIFE MEMBER
Southeast Ohio
The problem is, and I know of this first hand, the timing mark on a replacement pump it not always the same as the timing mark on your original pump. Lining up the marks will get you close, but as Mel said, it won't get it exact. This is the reason I have spent money on timing tools. While mine was right on by ear, I didn't even have a timing mark, so I was lucky and I would rather be lucky than good many days!!! :)
jauguston
Retired
Bellingham, WA
If you can't find the axle code (on the ID tag in the door opening or under two cover bolts on the diff cover) how fast can you go in second gear? My rig wirh 235/85-16 tires will go just under 50 mph in second gear and it has 4.10 gears.
Jim
john greer
i have gotten upto 55-58mph in second got 33inchers though so propobably not to acuate.
john greer
what is the timing tool called that i need? can i get at local parts house
anyone in arkansas who can time my 6.9???
Bo17
