smolkin
Stuck inside Mobile
Halfway through my return line replacement I realized I had a 6.9 kit...doh! Wanting to get as much done as I could before DeathStorm 2012, I put it on anyway, added a tee, everything plumbed up ok. But after searching some old threads here I am wondering...I have the IP return routed into the #2 end cap, will that provide sufficient flow? Or should I have a "dedicated" line from the IP back to the factory tee back by #8, like a 6.9 does? I would like to get this set up right the first time, as it will still be a little while before the engine is started to test it (or I try to start it). Has anyone had a problem returning the IP and driver-side caps on a single 3/16 line?
P.S. Used Viton o-rings and Gates Barrier 30r14 in 1/4 and 3/16 instead of the crap in the kit...should not rot internally and collapse over time I hope. I should post pics of what the B100 did to the OEM lines
edited for crude cave-man drawing:
