DeepRoots
Tug Engineer
We've been looking for a diesel to fit a few needs here on the farm.
basically run an irrigation pump and generate the occasional electricity.
I was looking at the slow speed listers that seem to be getting imported from India, and they look interesting. Tho for $2000+ and weighting 1k-2k lbs for a 6-12hp engine seems excessive.
so I was thinking I could probably pick up a 6.9 for $500-$1000 depending on condition and use it. I would guess it would probably make 30+ hp at 600rpm and weight a good bit less than the 'slow speed listers'.
Plus the obvious benefit of being able to rebuild it and stick it in my truck.
Obviously cooling would probably need to be upgraded, but otherwise could anyone suggest reasons not to do this?
things to look out for? etc etc
The engine would probably run at 600-800rpms for 100+ hours at a time.
thanks
drew
thanks
drew
