3g swap didnt work as planned.
Buffetkiller
Washington
I did the swap following the picture. The battery still wont charge. So my battery light is known to not work on start up. I did hook up the i from the alternator to the green and purple wire going to the cab. Can i hook the I from the ALT to ignition like some diagrams say? I wanted to check with some guys with knowledge before doing this
dgr
sac town
Run battery power to the I terminal and test output voltage.
There's a very detailed thread that was posted recently that goes through some testing scenarios.
dgr
sac town
Dun dun dun
  • 3ginstall.pdf
run it this way.
I just did that swap and zero issues.
also the heavy positive lead, I run straight to the battery or the starter lug.
dgr
sac town
That's how to wire it. If his charge light is not providing voltage, the alternator won't charge.
Buffetkiller
Washington
Ok thanks for the diagrams. Wasn't sure if the diagram i was reading was correct or not. Is there any keyed power near the starter solenoid or GP solenoid? I was probing around and only found a couple low voltage wires
Selahdoor
Index Wa
What did you do with the old regulator and it's wiring?
