NapaBavarian
Dually driver 6.9
If only I had a use for thirtysevens!
Any business address will work. I had mine shipped to my bar without a problem!
Any place that is zoned for business, or you can always pick them up at a local port/dock.
how does it change cost then?
.Those are pulled off of Humvees and you know they gotta be great tires if the military is using them. Supposedly the MT/R's are the next step up from the mil ones. Apparently the gov didn't think they needed the MT/R's so they went with the slightly cheaper MT's
yeahhhhh....that's not always true.i work on a military base and the humvees....are junk. militrary using "good stuff"? most of the hardware we get is CHEAP junk. just becausr the gvt. uses it doesn't mean its good.
those tires are ok, but not that great. a set of swampers would destroy them.
-Jon
Agree with dyoung. The old buckshots were the best tire. They either got you to go or got you stuck to the frame.
