Andy, two comments - I see your WTS light is blinking, did you rewire it at the controller relay? Also, you're idling way too low, actually that seems like a normal idle but after you drop off the high idle - are you sure your solenoid is working? You should be around 8-900 rpms when it's engaged. Oh yeah, in case you ever wanna wire in a manual switch for that, the high idle and the timing advance solenoids draw between 5A and 7.5A current, as yesterday when I installed mine I blew the 5A fuse but the 7.5A is holding up just fine.
