2005 f550 axles????
eastsideauto
Denton, NC
Not an IDI question but you guys know everything else.
What axles are in a 2005 F550 4x4?
ksingltn
Anniston, AL
Dana Super 60 front, dana 120 rear with a an 8x220mm bolt pattern. Most likely with 4.88 gears. Front will be set up for radius arms and coils.
FORDF250HDXLT
Maine & Oklahoma
the axles that would go very well under my 93 f450! :D
why,did you find a good score on a set?
asmith
Atascadero, Ca
That is my plan in a a year or so. except i dont need 550 axles, just go with '05 and up f-350 axles 3.73 and discs all the way around, plus a better ride and tighter turning radius!! yes i know about the unit bearings and having to swap rims, but my truck hardly sees any offroad so i dont think the unit bearings will be much of a problem.
kuskoal
Yokosuka, Japan
I'd definitely run the Super 60 with regular d60 unit hubs(8x170). Or swap knuckles to the old style and lose out on bigger brakes. Coil sprung, bigger u-joints and better brakes.
