**1996 f250 7.3 & 1994 7.3idi turbo questions**
boliIDI1010
Dundee, Illinois
Hi
I am looking at buying my 1st diesel truck. I have always had gas trucks. I am looking at a 1996 f250 extended cab 4x4 with the 7.3 and a nice plow. The guy is selling for $4000. Has 265k miles and is in nice condition. He says the injectors were replaced last year. Any input from you guys would be great. Should I be scared of 265k miles??
My other option is a 1994 F350 4x4 with a idi turbo 240k miles and zf 5speed trans for $4500 with a plow.
Please post your feedback oon both trucks. I sure would appreciate the help.
thanks
Can30Diesel
Agassiz BC
The 96 will probably be a powerstroke which is a good motor, but they are sensitive to maintenance. Parts for these trucks are quite expensive.
The 94 is about the last of the IDI motors with what is probably a factory turbo. The IDI's use a mechanical injection system which has proven very reliable over the years. Parts are usually less expensive for the IDI motors however there is a notable power difference between the IDI and the powerstroke.
Both motors are known to reach high mileage if maintained and both are good workhorses.
The ZF 5 speed transmission is a nice combination with the IDI motor.
You mention a plow so I suspect this will be a winter plowing truck which both trucks will do easily. If it was my choice I would look at which truck was better maintained and go with that one.
Iowa 73
FNM
IA
I have both engines, and I would take the Powerstroke over the IDI hands down.
Those miles are not a problem for either engine. The transmissions are what you need to look closely at.
boliIDI1010
Dundee, Illinois
Yeah
I am sort of leaning towards the 1994 idi turbo as it is lower in maintenance cost, has a cleaner body than the 96 and it has the zf trans. i appreciate all you input. any more suggestions appreciated.
thanks
PlumberPoopyHands
