rhkcommander
Didn't see anything regarding your turbo being bad specifically - does it have excessive shaft play? Any gouges in the inside where the blade is, chunks of blade missing or dings? Your hat being off means you were building no boost, turbo could be fine
black oil with the IDI is perfectly normal. You can do a fresh oil change and dump the fresh oil and it'll probably be black
For oil filter upgrades, alot of guys use the FL-1995 oil filter - its for a power stroke but fits ours too.
