1993 Ford F-Super Duty XLT - "Log Truck" (new to me truck-pic heavy)
junk
Paullina, IA
You know I've pulled many a tranny in my truck with two ratchet straps up over the frame tied to the nerf bars. Works better than you would think. I also am a fan of the floor jack with a board on it. I have a tranny adapter thing, but it sucks.
Good luck on the reinstall!
Jeremy
Here is my HF hybrid system.
It works pretty well. Motorcycle lift gives you the extra height you need sometimes.
FORDF250HDXLT
Maine & Oklahoma
What is big ORANGE tag?
it states (roughly) :
insure the bell housing is flush with block before tightening bolts to avoid splitting the case and torque bolts properly.
then in a different language under it,i presume it states the same thing again.
LEFT or drivers side core/freeze plug does not appear to have a nipple dimple as such likely a reman. You should be qble to feel a slight nipple outwards dead centre in dimple for stock plugs...aftermarket that I hqve seen do not have said nipples.
Cannot see right side plug...
Just wanted to add tidbit...feel for nipples in the dimples a d report back.
here is a pic of the pass side.i had to flake off the paint first.
both freeze plugs are as smooth as a babies bottom.they are indented but there is no secondary dimple nor nipple in the center.
FORDF250HDXLT
Maine & Oklahoma
today on the log truck show.............. it's time to update her audio system.
so iv had a new head unit and new speakers for a few months now but haven't had time to install them.so since log truck is currently home,she's down for repairs,parked in front of the garage and combined with the fact that the patriots don't play until tonight.....it was a recipe for a successful audio upgrade.so without further ado.....
ok so here on channel 444 you know how it works.i bring it to you fresh and current as always,so this just in from the last hour.
here is a head unit i originally bought for a past truck,years ago (1996 f-150) then i passed it down to chip truck before upgrading it's head unit,then finally into log truck.....the time has come however to ditch the old cd's and get a more modern system in here as well as ditch those 20+ yr old paper speakers!
this old head unit will still live on as i'll install it for my sister in her motor home.
attachment.php
here are the new goods to bring her tunes up into the modern age:
(oh.don't recognize that tan seat? i grabbed this off color super cab,split back,bench seat off CL a year or so ago,because the original gray was broken down and rode hard. a $40 special!)
attachment.php
so i rip both rear paper speakers out:
attachment.php
attachment.php
and in with the new 6x8's baby:
attachment.php
attachment.php
fit just like oem and look no different once installed.....but oh do they sure sound much nicer.;)
attachment.php
FORDF250HDXLT
Maine & Oklahoma
continuing on,as i install the front speaks and the head unit.
so i remove the door panel and rip out the old paper speakers.i dunno who remembers but once again you can see her original white color:
attachment.php
here are the new fronts:
attachment.php
installed with a couple self tappers with the cordless:
attachment.php
door panel back on,and repeat the process for the other side:
attachment.php
now it's time to drop in the new head unit
(don't mess with setting it up too much,as im just going to disconnect the battery again anyway,as her starter is still out)
and then it's time to crank up some DIO and test her out!:rock:
attachment.php
https://www.youtube.com/watch?v=W1f1_R9hVpI
hope you guys enjoyed this Sundays episode.see ya again soon as her flexplate is in the mail.;Sweet
for those interested in details:
www.amazon.com/gp/product/B00SYPYKOU
(don't worry,you can change the color from pink/purple to something else lol and i dunno why it says "sd card" it's USB.)
http://www.amazon.com/gp/product/B00A0LYU2S
http://www.amazon.com/gp/product/B00A0LYAU0
Nice audio upgrades are always terrific.....cant wait do some in my rig...need sub n some door speakers some wiring and be golden!!!
That was a terrific upgrade...no idea if sounds better cause phone sound sucks
FORDF250HDXLT
Maine & Oklahoma
thanks.i didn't record a clip anyway.that's just a youtube vid i posted for kicks and giggles.
it does sound far better.before it was like a tin can.now it's rich and full with some bass.
now i can toss the cds and toss a bazillion mp3's on a usb drive,hit the random button and be good for many miles.
FORDF250HDXLT
Maine & Oklahoma
today on the log truck show...........log truck gets a replacement flexplate.
bringing to you as it's happening on channel 444;
new flexplate installed with bolts torqued to 47 ft lbs.
attachment.php
so when installing a flexplate,you cant install it wrong because there is one bolt hole that doesn't have threads.so you know to cover this one up with the only blocked off spot on the flexplate so the rest of the holes accept bolts.so you can't frig up the balance.
wow! within 5 mins i slid the trans back and got her lined right back up! never gotten so lucky before.usually im jacking,tipping,tilting,prying,kicking,screaming,shoving and pushing for a good half hour if not longer before she lines up.that was nice.
attachment.php
there's got to be a catch.what i did i forget? lol.
looking around.....sure enough.dammit! the filler tube is trapped up too high.luckily i was able to slide her back just enough (leaving the two converter nuts i just loosely placed) to pop it out and bring it down where it belongs and she went right back together without incident...phew.
here we go.i got her on the home stretch now.a couple converter nuts started.all but one bell housing bolt installed...where did the last one go anyway? oh well.installed the cross member completely after snapping this pic;
attachment.php
then came in for lunch.it's all downhill from here.iv done this so many times now,it's like cake.:D
more to come shortly on the log truck show......don't change that channel.:)
FORDF250HDXLT
Maine & Oklahoma
this evening on log truck..........log truck get's put back together again.
so after lunch i continue on.now where did i place that last bell housing bolt? oh well......dropping a transmission is dirty work.dirty has no place when talking about electronic controls.so this is how i keep her connections clean during removal;
attachment.php
so after i hook up her connections and cooling lines,i finally replace those rounded off starter bolts.back when i first pulled this starter they were already rounded.you can only ask so much from a 6 point lol.
where the heck is that bell housing bolt!
attachment.php
so i use the 4 new converter nuts this time (though the ones i re-used last time,fortunately did remain tight) install the inspection cover,install her cross over pipe,make sure everything is snug up to this point.....still looking for that damn missing bell housing bolt.....
attachment.php
getting close now baby! just need to hook her drive shaft back up!......and find that gosh dang missing SOB bell housing bolt! where the heck did i put that? oh well.......so close now,i can taste it! i'll find that bolt when i back her up a bit..
attachment.php
attachment.php
it's that time again already! awesome! i can't wait to start her up and hope she sounds like brand new again!.......then back her up a little so i can find that frigging last bell housing bolt!!!!!!!
attachment.php
ok she's got enough fluid back in her again to run safely so moment of truth.time to glow them plugs and crank her over!
......clatter...clatter...clatter.....clatter......yeah baby! smooth diesel delight.:D
back her up a touch and look all over.....still no bell housing bolt! what the heck.come on man! oh well.iv got to pickup before dark cus the days are so short now.so i clean up and put away the tools and i look down into the bucket i drained the fluid into and remember......oh yeah,iv got to reach down in that slop because i dropped a 1/2 wrench back along.so i reach in and what do i find along with a 1/2 wrench? yeah! the missing bell housing bolt.so i toss that in to complete the project and log truck is back up and running again.took her for a mile spin down the road and she's just like new again.
i'll let the atf drain out of the tube and check the fluid tomorrow.i know she's close but it's just too tough to get it right on after getting the tube all wet filling her up again.feels like she might be a quart or two low still.bit late in the shifts.
anyway,that concludes this repair and this episode of the log truck show.hope you enjoyed.
until next time.;Sweet
Bart F-350
FRANCE
Log truck comes at a service station, owner jumps out and says to the service guy; fil the gearbox up, and check the fuel level please...:sly
Hmmm, that must be the cleanest gearbox I've ever seen, after all these flushes cookoo
And, how is she holding up for the moment?
FORDF250HDXLT
Maine & Oklahoma
haha yeah.she sure has had a quart or two of trans fluid run through her veins.she's running great.the new flexplate cured all that ailed her.i took her out on one last job a little bit ago to get a couple logs.
this time of year i park it.she wont hit the road again until spring but she's ready to roll.;Sweet
Tyler9828
