You should be able to lay the compressor over to the side, unbolt the condensor, and then lay it down somewhat flat. Then you just lift the engine over the top of it.
Although removing the core support sure seems like a lot of extra work just to keep something simple. Why are you pulling the engine out? I thought you are just wanting to swap to a ZF5.
I want to swap to a ZF AND insure the engine won't crap out on me. Take a look at the coolant:
Doesn't inspire confidence. Here's the bottom of the bucket after I disposed of the coolant:
It may be hard to tell, but there's a LOT of metal flakes in there. I'd rather do the hard work now and avoid headaches in the future.
