1991 F350 IDI Crew Cab Long Bed
Status
Not open for further replies.
psychohawk
Downey, CA 90242
Hey all, selling the truck ... never figured out how to post pics so if you want some, I can either text/email them to you or you can search for my truck on Los Angeles CL.
without further ado:
1991 Ford F350
Crew Cab Long Bed
226,*** miles
Clean Title
7.3 IDI Diesel Engine, N/A
4.10 rear differential
$3,995
I've owned the truck for just over one year. During that time I've put a bunch of money into it to make it my camping vehicle but unfortunately, I had to sell my camper and no longer have a need for the vehicle. It is also my daily driver so mileage will vary.
The Good:
~ rebuilt BW1356 manual transfer case with manual hubs
~ rebuilt E4OD transmission by the previous owner
~ new heavy duty radiator, proper Ford thermostat, upper/lower radiator hoses and heater core
~ new alternator
~ new batteries
~ new rear tires
~ speedometer geared properly for tire size, no speedometer discrepancies
~ new power steering gear box
~ A/C upgraded to R134
~ upgraded head light bulbs with upgraded wiring and relay integrated into circuit (no cut, easily reversible if you don't like)
~ reupholstered front bench seat and rear bench seat
~ newer rubber floor mats
~ amazing interior, probably the nicest you'll fine for this age and miles
~ sliding rear window
~ tinted windows
~ factory Ford stereo (hey, it looks nice and works fine!)
~ Happijac camper tie downs for cab over camper
~ lots of receipts, most work done by a professional mechanic
The Bad:
~ engine temp gauge inaccurate, started last week, needs sensors, about $100 for both
~ A/C went out Sep/Oct, needs compressor, about $200
~ needs drag link replaced, about $75 (might do this weekend)
~ sometimes turn signal stays solid, needs dis assembly and cleaning
~ rear quarter panel damaged, passenger side behind rear wheel, from tire exploding on freeway
~ tail gate doesn't open/close, I dropped a hot water heater on it, but I do have a replacement stored, same color, in northern California
The Ugly:
There is nothing ugly about this truck! :)
$3,995
Thanks for looking,
Carl
562.895.8871
Status
RangerDanger
