Methinks that cowl seal is a vital part for the preservation of the engine.
I bet the gasket failed to the water port and jacked the plugs out.
I think this is a true solution to the soft plug problem. It is more of a routine habit of mostly gas engine rebuilders. The stainless plugs will not rust out. Next time they stay in!Or dont remove them.
imho you're geeking out too much on detai. there's no reason to be nervous on a 6.9 block. there's no porosity issues, and the deck surface is pretty stable compared to others. If it was mime, i'd either drop a set of 8 sleeves or go with the ****** block and do the bore/hone. dropping in 4 sleeves on one side and leaving the other side alone would be my last choice.So I spoke to the machine shop today. The one issue I ran into is that when doing a sleeve repair to an engine that has all the other cylinders at finished bore is that the press fit of the sleeve will "push" the adjacent cylinder out of round. This is normally not an issue since the last step is to finish hone all the cylinders. They indicated they could fix the issue on cylinder adjacent to the "repair" sleeve by honing, however my issue is that the piston clearance is already set so honing it back to round will increase piston clearance, which was blueprinted.
So the options seem to be to sleeve all 4 cylinders on that bank or get another block. This block was the most perfect core since I had control of it all of it's life. I have another block lined up that will need hot tanked, bored, cam bearings and decked. But not really any history other than it was running, had a blown head gasket and it is a late block.
I would compare all the rebuild costs to a Promar remanufactured 7.3 engine. They do not reman any 6.9. That is if the truck chassis is not a rust bucket.
