just did this. The 05+ has a different MC bolt pattern to firewall than my 91 truck. I redrilled the master plate put new 3.8 bolts in and tacked em in place. the factory pushrod fits on the 91 brake pedal assembly fine. However if you want it to be in line-you will have about a 1/2" gap between booster and firewall. In hindsight i would have placed the new bolts 1/2" lower on the backing plate.
Also, the new SD pushrod is a little longer than the obs one, so it needs to be spaced out form the firewall about 1/4" or the MC wont retract fully and wont suck more fluid into the lines.
I dont know the size of the fittings on the HB unit, but i know the factory 05+ hi pressure line is a direct fit into our old style PS pumps.
any other questions feel free to ask.
actually..just though of this, if you place the MC a little higher (the bolt spacing i mentioned earlier), this woudl create a slight angle on the pushrod, which might aleviate the pushrod being "too long"
edit: just saw this is for a van, so the pushrod is yet different than the pickup. but same principal.
Press the original 05+ studs out, line up on the firewall, see where your pushrod is in relation to the brake pedal, drill and put new studs in accordingly.
