Steve Olkowski
Hi, I have almost everything here to install sidewinder kit. At the same time I have a freshly rebuilt DB-2 5070 pump I would like to install. Can I remove front cover and line dowel pin to the top, and remove pump, marking the gears so they don't move, and put new IP in making sure gear inside doesn't move.Can it be done that way and stay in time? Also once turbo pump is on, will truck run without turbo installed, or is it time to go all the way? Thanks, Steve
