1989 7.3 voltage regulator on a 1986 Harness. Will it work? What is the 4th terminal
SkylabTech86IDI
Southeast US
Hey all I have a 1989 F250 7.3idi voltage regulator and a 1986 harness F250 6.9idi
The voltage regulator has 4 male connectors on it and the 86 harness only has 3 female connectors - do I need an 86 specific voltage regulator or will this one work?
It will work. Ford had two different ways they wired the regulator.
The 4th termiinal which is the "I" terminal is only used in a truck that has a "GEN" light in the dash. The 87 has this with a voltmeter in the dash also.
The other way is a truck with a ammeter. The 86 truck had a ammeter,, so the "I" terminal is not used and the alternator is wired a little different. This will be taken care of if you are using the complete 86 harness. The regulator is the same and the alternators can be the same also. A lot of the old early 80's f100s had idiot lights instead of gauges, and those would have used the "I" terminal also.
SkylabTech86IDI
Southeast US
Thanks for the response franklin2. On the voltage regulator harness, it looks like this secondary S wire should be grounded out to the firewall, is that right?
How does the wiring to the alternator look?
In your case, the "s" wire to the regulator goes to the ignition switch. The "s" wire on the alternator is not used. Here is your 1986 wiring diagram.
Bsmith293
Can you tell me where the black yellow and orange wire go to off of the alternator?
What are all the color wires leaving the alternator? Do you have a external voltage regulator? What year truck are you working on?
And really, if you're close to Crestview Florida since you're in the "southeast" i have an entire 3G wiring harness and alternator ill give you a deal on...... PM me.
Oiler
