Same code I was getting... But the transmission computer never sees raw VSS.
What threw me for so long is that my speedometer needle was steady. Which led me to believe I had clean VSS signal.
It wasn't until I scoped the VSS signal that the PSOM was giving the PCM that let the proverbial cat out of the bag.
My PSOM output signal was available at a connector that was intended for cruise control. Which made it much easier for me to tap into.
I found this helpful.
http://www.atraonline.com/gears/2007/2007-01/2007_01_04.pdf
I had decent VSS going to the PSOM, but the signal leaving my PSOM would intermittently drop out. When I bought the beast, it did this rarely. Maybe a few times a month. But it slowly got worse.
My speedometer needle was steady. Fooling me to look elsewhere. I finally got so desperate as to buy a battery powered oscilloscope and start tapping into the control signals. VSS to PCM was first, because that was what the error code was pointing to. Yup, next time the transmission went amuck, there was no VSS signal either.
Yet, the speedometer was still showing proper speed. Looked like I was getting good signal to the PSOM. But not get
ting anything out.
So, l got another off of EBay, did a swap, and I have not had another episode since.
One thing I will leave with you. I discovered I could usually induce the gremlin by rapping on the speedometer reset or select buttons. Not consistently, but the probability of my little gremlin was quite correlated to my doing this.
Incidentally, if you have an audio frequency generator, its easy to bench test to verify your new PSOM works. I used a 600 ohm 1:1 audio line transformer to isolate the VSS input so as to make the PSOM think its seeing a coil of wire in a magnetic field.
There is an android app on F-droid that turns an android phone into an audio signal generator. I did not test this way, but it looks like that oughta work... I would still use a transformer for isolation though. I am talking those little audio transformers that were so common a few decades ago.
