Wheels that will fit a 1988
carsonsupple65
Hi guys a buddy of mine drives a 2002 Chevy Silverado 8x6.5 lug and he has 20x12s on his truck and he is planning on selling them I’m wondering if they will fit my truck anyone know ?
u2slow
bilge rat
Coastal BC
Since they're aftermarket, center hole should be large enough. 12" wide wheel... that's a lot of wheel. Probably make the tire rub your leaf springs when you turn.
Oledirtypearl86
Whitehall MT
That they do and I know mine have a pretty good offset maby he will let you try 2 out and you can check to see if they rub
catbird7
PA
35's on my F350 required 2.7" leveling kit on front. Also added 2" steel wheel spacers to rear axle so they "tracked" in line with front.
compressionignitionrules
Bluevale ON
you haven't posted the tire size, just the rim size. they could clear with no issues if they are low profile 20s, if they are big 40" tall mud tires you might have an issue.
"your truck" is ?
go for it, they'll fit.
720Diesel
