jwsfarrier
I have been chasing a fairly good oil leak since I did my rebuild. Couldn't pinpoint it at first, as it was probably coming from multiple places. I was getting oil driipping down the back of the starter and oil pan. Decided to go back in and reseal the top of motor just to cover all bases. The leak was less but still there. Thought maybe rear main, but after pulling inspection cover youj could see where the oil comes down and run across then down back of pan. Long story short, it appears I have an oil leak coming from under IP. It looks like it starts towards the back ,but could just be where it ends up dripping down. I'm assuming it starts where the pump mounts to the timing gear cover. I'll try to get some pics up. Thanks everybody
