chris becker
So I just got done doing new glow plug on my 1993 with the 7.3l in it. I have had a diesel leak up in the valley between the heads and intake manifoldsince I got the truck a year and half ago. I was leaking when I got just didn’t know where because of all the leaks I have fixed. Well I got curious today cleaned everything off with brake cleaner and wiped the valley dry. Changed out my bad glow plugs and restarted it. Looked for the leak and it is coming from out from under a plastic cap near the top of the injection pump and running down the side. It is the cap by where the injection lines are coming off of the pump. In my pictures (sorry they are upside down) You can see the moisture coming from the plastic cap. Can I pull the cap and tighten what is underneath it or do i need to take it to an injection shop and have them do it?
