NapaBavarian
Dually driver 6.9
When I use synthetics it's castrol, AMSOIL is a marketing company
The right oil filters for Ford diesel engines
Designed for Ford Power Stroke® Diesel applications
7.3L diesel engine oil filters are up to 98% efficient at 18 microns or larger and feature anti-drain back valves to help prevent dry starts
6.0L and 6.4L diesel engine oil filters are up to 95% efficient at 20 microns or larger and feature top-loaded, dripless cartridge elements
Recommended by Ford Motor Company
Some Contaminants Cause More Damage The level of damage particles cause to
an engine is directly related to the size of the particles. The oil stream
within the engine flows between wear-sensitive surfaces that usually have
clearances of between 2 and 22 microns. It is contaminants in this size
range that pose the greatest threat as they can slip between moving
components, causing a great deal of wear.
To appreciate how small these particles are, one must first understand the
measurements involved in their classification.
A micron, or micrometer (µ), is a very small unit of linear measurement.
One micron is equal to one millionth of a meter, and 25 microns is equal to
0.001 inch. To better put this in perspective, consider that the diameter
of a human hair is 50 – 70 microns.
Large particles are particles measuring 1/2 or larger. They pose little
threat to engines because they are easily removed by the air filter.
Medium particles are particles measuring 25µ to 1/2 . While they are of
greater concern than large particles because they are more difficult to
remove, the threat they pose is diminished since they are still larger than
many of the clearances within an engine. Their size will not allow them to
enter the contact areas between many components to promote accelerated
wear.
Small particles are particles measuring between 5 and 25 Microns and Larger
Bearing Bearing 25µ. Small particles are of greatest concern because they
can penetrate the clearances between wear-sensitive components and promote
accelerated wear. And, because they are so small, they are difficult to
remove from the oil stream.
SAE Testing In the 1988 Correlating Lube Oil Filtration Efficiencies With
Engine Wear technical paper published by the Society of Automotive
Engineers (SAE), the relationship between oil filtration levels and
abrasive engine wear was established. Testing determined that wear was
reduced by as much as 70 percent by switching from a 40µ filter to a 15µ
filter.
The SAE conducted tests on a heavy-duty diesel engine and an automotive
gasoline engine, and both provided consistent results.
WOW I was just looking for some friendly insite and a war broke out
Not an ounce of actual fact just crybaby whining.
we need fact's not blah blah blah whatever whatever.
nothing special here, more facts below
How is that K&N air filter working for you guys, NOW?
More info below
You dont like facts cause they make you feel insulted?
Dont attack the content attack the messenger, I see how you think...
thank me thank me very much.
Javier
hold your K&N filter to the sun light and see how many holes in the 200/300 micron rating you will see, to answer your question YES your K&N filter SUCKS DIRT into your engine.even tho the tone is bad some good info. so does my K&N air filter suck?
OK, thank you thank you very much for showing everyone here how arrogant you are with the knowledge you have. Why not share that knowledge in a respectful manner? Why not be a real man? Men that act like you have some kind of complex. What you know would definitely be appreciated here, but the way you choose to bring it out makes no one want to listen, except to say "you're a *****", "you're an ass", etc. Because when you choose to respond like this, YOU ARE.
Like I said before, Man Up! Show some respect where it's due instead of just flying more crap at everyone. If you think it's more "crybaby whining " then get outta here and go someplace else.
Man Up ****
OK THATS IT I AM BUYING AN ELECTRIC CHASE1
you quoted me and took out the facts I posted, you call me arrogant?
Javier
I've been really curious what your truck is set up for.
off road racing chase truck gota go getit when we break it.
