you are soo rude!
watch out the feelings police are here
Javier
Yeah I'm in no mood tonight to argue with him about it. I'll just continue to do things the way I've always done them and leave it at that.
you are soo rude!
Javier
the larger filter only holds more oil thats it. If you want to catch MORE deposits you need to find a filter that catches smaller deposits, then you are getting places...
Javier
I dont doubt you, but I did post up the information back a few pagesWrong, THe PSD filter was re designed with a finer element specification due to the high pressure oil pump fuel injection system on those beasts. You've got oil going through very small passages at around 10,000 psi and the system requires a level of cleanliness a step above that which was speced for the IDI engines.
Using the OEM oil/filter in a PSD still causes the romp romps in the morning.The right oil filters for Ford diesel engines
Designed for Ford Power Stroke® Diesel applications
7.3L diesel engine oil filters are up to 98% efficient at 18 microns or larger and feature anti-drain back valves to help prevent dry starts
6.0L and 6.4L diesel engine oil filters are up to 95% efficient at 20 microns or larger and feature top-loaded, dripless cartridge elements
Recommended by Ford Motor Company
