zf5 parts needed
93_444idi
first on race day
missouri
needing crossmember, pedals, and a stick/boot. already got master/slave cylinders and manual center pan (dont know what to call it) as well as tranny/transfer case. im going up another 2" and gonna need different driveshafts anyways so im not concerned with them yet. can get a SMF here cheap and I'll get my clutch new. anyone got anything lyin around?
itsacrazyasian
residentcrazyasian
boca raton, fl
the pedal assy? get it new from ford. it was instock at my dealer. under 100 bucks if i remember too. Updated unit. thanks to towcat for that heads up.
6 Nebraska IDIs
The sticks and boots are very difficult to find in usable condition. We are running 2 trucks right now with loose boots because someone destroyed the trim piece when they couldn't get the screws out.
zpd307
Zumbrota, MN
ya, i had to get several pedal assemblies for mine when i converted. a lot of bushing were worn out and ate away at the aluminum housing. i have a new set of bushing laying around if you need them. for some reason i bought two sets.....
Ya the two boots for the ZF here in Canada inner and outer boots...near 200 bucks!
What year are your bushings for? I am just about to install my pedals and was thinking of installing new bushings. How much?
dyoung14
Is getting worn out
spencer,tn
I have a pedal assebly, its in good shape, i might even have the boot, but i know i dont have the stick i used it on my truck
don't buy used.
see pics.
the last pic is the updated unit.
zpd307
Zumbrota, MN
the bushings should be for 97-91. i will run the part number on the bag when i get home in the morning. i think i paid $20 a set from the stealership, but i can check on that also, and cut you a deal from there....
