Yikes! That couldn't have been good
Cubey
Van dweller
I decided to start replacing the front shocks on the RH side. After removing the wheel, this is exactly what I found.
No, I hadn't unbolted the top. The nut was already gone. The stud isn't broken, it has the smooth top before the threads begin. I don't know how long it's been that way, but the side area has some minor rubbing. It might be recent, since I'd expect more wear.
Old, stuck completely compressed -vs-new, completely uncompressed.
It was a pain to install because Bilstein doesn't put the plastic compressing thing like Monroe does. I had to use a tire iron then and a bottle jack with a socket set on top to compress and align the shock with the bracket and bottom bolt.
One side down, one side to go. The other side is still attached up top. I'm taking a lunch break now, but I'll reply with more pics later probably.
Cubey
Van dweller
Nothing to really to say about the other side. It was normal. Shock still seems somewhat serviceable. Replaced anyway of course.
dgr
sac town
You need a bumper sticker
If the Van's rokin'
Might want to check the shock bolts
Cubey
Van dweller
If the Van's rokin'
Each shock came with a Bilstein bumper sticker, if that counts.
  • Like
Reactions: dgr
Cubey
Van dweller
Holly cow! You should replace the ones in the rear as well for 40 more hp!
I put new Monroe Gas Magnum RV shocks on the rear last May. It's all I could afford at the time and it needed em bad.
frankenwrench
overkill is under rated!
Weatherford tx
Did those come with stickers? Lol. Joking aside, I had a rear shock on my truck dragging behind me on the driver side from Odessa all the way up to McKinney before I realized it was scraping behind me. Still an easier fix than a front shock though. Not sure how difficult the Vans are but doesn't look like you have all the room in the world.
Cubey
Van dweller
Room is different on each side due to the fenders.
RH side, a socket wrench fit. LH side, they left a cavity to reach into with a regular wrench. It took forever on that side. I stopped and did other stuff a few times because it was so slow going. And you are supposed to tighten the top with the vehicle weight in it, so then the tire is in the way too. Maybe some swivel extensions would have helped.
olsen726
