Okaaaay,
Where are your filters located relative to your pump(s) (before/after), and what kind of filters/pump(s) are you using.
I am just about to redo my fuel system and would like some ideas.
I have the factory filter, 2 goldenrods (12, 10, & 5 micron filter elements), and a couple small disposable filters.
On my van, the fuel exits the single tank, goes 12ft forward to the lift pump, goes 9ft rearward to the factory filter, then goes 8ft forward to the IP. I think this is a really poor design, unless all the hose had some other purpose than transporting fuel.
My factory lift pumps works fine, but I'm thinking of removing it and going with a single electric pump. Accessing a dead lift pump on a van is a miserable job.
I'll be running WMO from a separate tank too.
