WMO with water injection
DGT
texas
Would water injection help keep injectors and motor clean when running
wmo / diesel mix? Has anyone run water injection with diesel? If so what
results? Seems my injectors get dirty after 1500 to 2000 miles of running
50% wmo and 50% diesel causing alot of smoke.
BenPutnam
Pleasureville, KY
I've been thinking about this myself and I think it would keep it clean but you wouldn't want to run it while you were running a WMO mix because it would cool the combustion process. It would work well for someone with 2 tanks.
subway
be nice to the admin :D
York PA
sasslrel who has been running WMO says it works well, maybe he will chime in here. you plumb it in to come on under boost and such. people use it to gain some more horse power on regular diesel trucks but that is just a side effect of what we want, cleaning the carbon.
from what i know you need a small pump, tank and you use a nozzle to shoot a mist into your intake.
funny part is my truck smokes more on a diesel mix then it does running 100% WMO.
pwillis
