sonic reducer
How viable is an onboard wmo filtration setup? Up front I will say that I have no experience with waste oils in general although I have been reading around here and elsewhere a bit. I would like to get into waste oil(WMO specifically) but just cannot justify having the equipment stationary at my house. I live in an urban environment, my garage is in the basement and space is at a premium. I don't want a big barrel of oil inside the house. my neighbors are lame-***** so I don't want to do it outside. I like to fly under the radar whenever possible. All that said, wmo processing on the property seems questionable.
I figure if you were doing smaller batches you could run smaller tanks and use the truck's systems for heating the oil whether that was coolant lines or 12v. the filtration systems are compact enough per component that they could be mounted wherever they fit under the bed and then plumbed to suit. on a truck with dual tanks you could have a collection tank up in the bed somewhere, say inside a truck box, which would pump or gravity feed into the second tank. run a dual tank type system to the truck's fuel system. front tank diesel, or known good fuel, rear tank waste fuel, with secondary filtration between the two. so the flow would be collection tank-coarse filtration-secondary tank-fine filtration-primary tank-fuel system. Possibly even simpler than that? Why doesn't anyone do setups like this for WMO?
What other considerations can you guys think of for a setup such as what I am suggesting? Functionality, safety, legality, cost effectiveness, and convenience all are factors. If there are factors that I am not considering, please set me straight. I'm sure there are plenty.
some WMO collection questions:
Are shops/wmo suppliers likely to be willing to deal with a guy who wants to pump wmo straight to a tank attached to the truck, similar in appearance to a transfer tank? of course this will not be cut and dried but maybe there is a tendency one way or another?
Are shops usually willing to dispose of wmo to a random unknown person at all, and if not, why?
what are the usual methods in which shops dispose of their waste oil, and are they paying for it?
