I am about to start my 89 F250 5.8 to 6.9 swap. My donor truck is an 87 F350 C&C. When I pulled the wiring harness out of the donor truck, it appears that EVERY wire at the round firewall plug has been cut and spliced back together! The harness is a MESS to say the least. Should I go through it and make sure the splices are done correctly, or look for another harness?..OR can I use the gasser's harness? What about the under dash harness? Does all that need to be swapped out as well?
Thank You
Thank You
