Goofyexponent
Mentally Unstable..
There isn't too much I can't figgure out wiring wise....but I am COMPLETELY stumped as to this.
First off, my test light is in the Kenworth at work...so I am working with a multi meter...requires a bit of creative body english to make both connectors make contact, but it works lol.
Now, the PO repaired EVERYTHING with 14G white wire...and I do mean EVERYTHING.
I need trailer park lights. I have at the trailer connector (7 pin of course)...brake lights, both signal lights, the trailer brake wire is live and working properly.....I jsut can't get park lights!!
I found out that my trailer connector isn't wired into the back of the truck correctly. SO after removing and repairing the suitcase connectors that WERE on there I STILL can't get trailer park lights.
I found a white wire (of course) that runs from the park light pin up under the hood and then I lose it in about 12 white wires. This HAS to be the park lights.
Another bit of info, is I can get about .8 volts at the park light pin in the connector...and that's it!
Bottom line is, I have everything else working..the fuse is good, the relay is clicking on, but no park lamps!!
