Who else is looking for a DT360?
hesutton
The Anti-Anderson
Bowling Green, KY
Another advantage the DT360 has over the Cummins is it's wet sleeve design. If the bores are worn or you have a bad cylinder, just pull the bad sleeves or sleeve and replace. No need to go to the machine shop.;Sweet
Heath
hesutton
The Anti-Anderson
Bowling Green, KY
It's relisted yet again...... HERE. I don't get why he says "This is a NO RESERVE AUCTION - BID TO WIN!!!!" when he has a reserve price.cookoo
HERE IS ANOTHER that is close to me, but way overpriced.:dunno
Heath
rhkcommander
Oregon
aren't the 360 and 466 the same length? i know the 466 is taller and wider. Also has anyone figured out the mount for zf5 or w/e? ty
hesutton
The Anti-Anderson
Bowling Green, KY
Nope, completely different block. The DT360 is only a inch longer than the 5.9 cummins.
As far as an adaptor plate to hook up Ford trannies to the rear of a DT360.... already be done.
Heath
RLDSL
Diesel fuel abuser
Arkansas
Heath
Ebay calls that a bait and switch, I filed a report, and I suggest everyone do the same. Let's see what happens. THey have a link right there on the listing below the seller info now to make it easier to find.
rhkcommander
Oregon
zf5 can handle the torque decent? i dont need a million speeds I just want a solid strong power plant (like the dt series with their nice wet sleeves) and a good method to put it to the wheels. I like my 4x4 too but I got the T19 not the zf5
Diesel JD
Gainesville, FL
Heath
Hey Heath...with the adapter...can you give us some more info...such as price, where to get it? Or can we just use the Ford-SAE3 adapter our IDIs and PSD trucks have? I'm not in the market now and may never be but it's surely possible. Actually if hooking up the Ford trannies and the DT360 seems feasible I'd say with something like a DT360 or even a Cummins something like a T18 or T19 with a brownie or DNE2 box would be preferable to a ZF5, but to each his own.
Clydesdale
Nampa,Id
I am NP435 and a net final drive of 2.95, I be good with a divorceable bell....
Enlighten us on said adapter.
Diesel JD
Gainesville, FL
Black Dog how in the hell are you getting a final drive of 2.95 with an NP435? Tranny is stout, I'd never get rid of that thing but you need you an aux to get you a better fnal drive with that Cent especially. I'm thinking she's 1:1 in top gear just like my T18 from behind a gas motor, only your first is even lower than mine (6.69:1 right)? My final ratio is 3.55 approximately and will be 3.02 with the brownie.
Clydesdale
Nampa,Id
Found another 3126 today... the temptation is strong for this one...
Any one need a pimp 6.9, wastegated ATS, PSD intercooler, NP435 1356 set up, include the exhaust, 3" DP to 4" all the way back...
Diesel_brad
Dunce
gilbert pa
Not much to explain. The small cat engines are junk. Anyone that has delt with them will tell you the same thing
cetanefreek
Star / Idaho
power efficiency durability and reliability SUCK compared to their big engines or Cummins and IH equivalent engines, that said I didn't have any problems with the 3126 in my service truck until about 7000 hours of operation. at that point the valves all dropped at almost the same moment, $15,000 for Cat to fix it.
part of it was surely gearing, but even with the new engine it still only got 7-8.5 MPG at 65mph.
