Twostacks
I have a 94 F250 7.3 IDI Turbo with 5 spd that I converted from DMF to SMF. I have about 4k miles on it since the conversion and the starter started to grind against the flywheel teeth on the flywheel, thinking it was a bad starter I replaced it and it did not resolve the grinding issue. I checked the flywheel and found 4 spots that the teeth were worn. I went online to find a replacement and found a few but they list different teeth count.
My question is what teeth count should I be looking for or does it matter, mine has 154 and now I'm wondering if maybe this is why I'm having problems with starters. BTW all components, flywheel, clutch, pressure plate, bearing, and starter were new. Any help would be greatly appreciated.
