Matrix37495
The Amish Wolfman
I was looking at RockAuto's offerings and didn't know if i need the 11" or 12" clutch. Can i run a 12" if i have an 11" now?
6.9L flywheel with a T-19....
Wayne, I'm going to get it resurfaced if i can find a shop to do it, but i'm going to replace the clutch cause i only want to do this job once.
Dave, I would have thought a needle bearing would be better than a bushing. How does that work?
So what's the final answer on the clutch size?
You can go 12 or even 12 1/4" (which is generally a redrilled 12" to fit the 12 1/4 but gives a little more surface area ) if you go to a SMF with the larger discs, you end up getting basically as many dampening springs as you had with the DMF so essentially no rollover noise, where an 11in in a smf has only 4 springs in the hub, and reusing an old DMF is playing with fire. Definitely get the lkevlar pilot bushing, trouble free operation * if installed properly*
