Which Belt?
jhenegh
Truck Still Earns its Keep
Deerfield, WI
So my belt is squeaking up a storm. Yes I'm gonna look at idler/tensioner once I get it off. Held a long screwdriver to the vac. pump and didn't hear the squeak coming through it.
My truck is a 1994 F250 IDI with the factory turbo
With that said, asking for a belt for a !1993! turbo diesel (helps eliminate Powerstrokes) F250 at Autozone gets me the options of a 110 and 113 inch belt. Napa lists a 111 inch belt. The one on my truck is 112 (Gates K061120). What?:mad:
Rockauto Shows the GATES Part # K061110 for a 1993 IDI w/ turbo
Rockauto shows the GATES Part # K061120 for a 1994 IDI w/ turbo
Someone please help me figure this one out. It runs with the 112" belt
Thanks
You need to memorize your 8th digit on your vin. They should ask you this in the parts stores when you get parts. I wonder what NAPA list for a 94 idi? Your vin is a "K" correct?
Autozone lists a 111 1/2" long belt for a "K" engine. I think the "F" is the powerstroke and the "M" is the idi with no turbo. All 3 are listed as options in 94. Ford never disappoints in their effort to confuse.
jhenegh
Deerfield, WI
Indeed I've got a "K"
Armed with that knowledge I'll hit up Napa here in a bit and see what happens
