the fuel filter heater line they tapped into the fuse in the power distribution box that also supplies power to the transmission.........cheap ars ford.so when the heating element's connector fails and leaks,it will short out the power to the trans control unit.i believe over time,this killed the tcm in log truck (f450.)
if the OD light is dim (approx 1/2 it's normal brightness) and the cancel button doesn't appear to do anything,then likely the fuse is just blown.
in log truck,my fuse was still good.the fuel leaked shorting out the line,but didn't blow the fuse.over time it did something to the TCM and i had an extremely dim od light (different than when the tcm just looses power.only 1/4 brightness) but the TCM was still functioning as normal as did the od cancel switch.i still replaced the tcm before it just failed on me though.hopefully you caught yours in time and it just fully shorted out and popped the fuse,which is no doubt much more likely.
i plugged and tapped the hole and ditched the power supply wire from the circuit.if i ever wanted a filter heater again,id get a universal wrap style and run a devoted power line from a relay and fuse,no longer on with power that feeds my expensive transmission.
being a 2wd truck though,she'll be just covered by normal insurance through good weather and left parked from Dec-April every year anyway so a heating element was of no concern.i don't even have one in chip truck which does see some winter use.
