Wheel simulators
SLittle
Iowa
I was given a set of wheel simulators (hub caps) that are the correct size for my dually. The factory lug nuts have a heavy washer built in to them. The simulators are just one piece for each wheel. Not sure if there is supposed to be more to it.
Do I simply remove the lug nuts, place the simulator on the wheel, and then tighten the lug nuts down over the simulators? Not sure if having the "hubcap" between the wheel and the lug nut washer is proper.
Also, would there have then been something to cover the centers?
chillman88
Central NY
