What update/upgrades available for 7.3 transmission cooler
fraree
Inland. Australia
Well back to the question, what after market coolers have the least recalls/issues. A genuine 6.0 cooler is nearly $700 here in Australia. I've seen a few different brands which look the same on Rock for between $150-$275 Au ? Is the Dorman model any good, it's $275.:dunno
I've seen heaps of "el cheapo" tranny oil coolers on fleabuy too. I won't marry up a cheap cooler to an $8500 rebuilt trans. Back to you people ;)
We're having a lovely heatwave down under, 100F + all week. :eek:
trackspeeder
Stone crusher.
North Branford. CT
I haven't found anything bad about the Dorman part yet.
What ever cooler you use. Be sure to use a stacked plate cooler. Not a tube and fin type cooler.
True Cool by Long is a very good part. They are the Ford coolers without the Ford brackets. They come with universal mounting brackets.
fraree
Inland. Australia
Has anyone used a hydraulic oil cooler in this application. The support frames on them appear fairly heavy duty ?
mike_hurd2000
Denver
I hare had the dorman 31 row cooler on my 7.3 for several years and have had no problems with it at all keeps the trans real cool.
red41neck
Georgia
2001 7.3 SD 4x4 Crew Cab {Stock }. I used a cooler from a 6.0. Yes it was used, cleaned it well and mounted it.
Had to find one reducer fitting, brass 3/8 to 1/4 if I remember right. So much better than the oem setup.
My old factory setup would go into limp mode on hills with my 22' closed trailer and Model A ford car inside.
No problems since.
truckonfire
