I need to try to snug up the input fuel line to the IP on my RV due to the bad olive. Doing that has worked on my F250 when I have done it a few times (once a year it needs it done) when it begins to seep fuel. I can't remember what size wrench it takes and it's so buried on the van chassis, I need to know what size to use before I try reaching in there to avoid much frustration.
Oh and is the input line nut a different size than the injector output lines? Just wondering for when I am mostly blindly trying to get the wrench on the nut. If it's larger, I can't accidentally fit it onto an injector line. If it's the same size, I'll have to be more careful where I slip the wrench onto.
Yeah replacing the olive, if not just replacing the line with something that doesn't use olives would be the proper fix, but it's NOT easy to get at on this thing. I suspect the turbo might have to come off to reach it from the dog house side, and I'm not in a position where I can do that right now. The leaky olive is causing air intrusion into the IP when the nose is parked uphill any sort of amount. I'm trying to be gentle on the starter (which may very well be the original from 1985!) but it stinks to have to do 3 rounds of long cranking so often and I might end up needing a new starter before long if I can't snug up that olive to buy some time before I have to replace the olive or hard line.
